Feature Requests
Instant replay "jump to" shortcuts
Joined: 12/27/2012(UTC) Posts: 5,530  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Unless i am missing the trick
Missing a shortcut to jump to the end of a selected event to allow for a quicker fine tuning/resetting of said position with a shuttle and adjust shortcut
While selecting an event automatically jumps to the beginning of the event another shortcut to do that while selected it would be beneficial too
is not so much a problem for 5 second or so events but the longer ones take up a lot of time to adjust the end as one has to grab the mouse and drag it over the end time which is very fiddly,slow and unprecise especially when one has a lot of them (hundreds, no kidding) to adjust on the fly
Thanks for considering
PS The ability to live create a (timed)event within an allready started event would be nice too , but found a workaround for that (script ofcourse ;-) )
Joined: 2/23/2019(UTC) Posts: 137  Thanks: 19 times Was thanked: 29 time(s) in 26 post(s)
If you use the ReplayMoveSelectedOutPoint shortcut it will jump to the end of the event, so what I use is adding a frame and then taking a frame off.
Function=ReplayMoveSelectedOutPoint&Channel=Current&Value=1 Function=ReplayMoveSelectedOutPoint&Channel=Current&Value=-1 (Value=0 doesn't do anything)
 2 users thanked RichDanby for this useful post.
Originally Posted by: RichDanby  If you use the ReplayMoveSelectedOutPoint shortcut it will jump to the end of the event, so what I use is adding a frame and then taking a frame off.
Function=ReplayMoveSelectedOutPoint&Channel=Current&Value=1 Function=ReplayMoveSelectedOutPoint&Channel=Current&Value=-1 (Value=0 doesn't do anything) Cool, thank you, nice workaround
Feature Requests
