Some time image not display on vmix overlay.
Hi All,
I have create XAML overlay to for VMIX. It working fine on maximum case but In Some case the image not load on overlay.I have create an application that use VMIX WEB API to bind image and text data dynamically on the VMIX. In case when image in not display in overlay .I have checked XAML bind data value in title editor property of VMIX Overlay. and that title editor window contain all the bind field data. So It mean my application send data to vmix application and VMIX also set that data or overlay.But VMIX not able to update that data to overlay.Because when I remove and add overlay again all the text and image display in overlay.
If Any one have any other solution then Please share it. Because I don't want to remove and add overlay again for VMIX .
Please let me know if any other information is required for resolve that issue.
Joined: 2/18/2014(UTC) Views messages in topic : 1,847 Location: Stockholm
I am not sure I exactly understand what you mean. Could you explain step by step how you send/change images in the overlay via API. So we can help you further.
richardgatarski wrote:I am not sure I exactly understand what you mean. Could you explain step by step how you send/change images in the overlay via API. So we can help you further. Sorry for not so clear about my application working. I have prepare a doc that will give you all that information about my application working and how that application communication with vmix. Please find that attache doc. Let me know if you need any other information. File Attachment(s):  Applicationworkflow.doc (21kb) downloaded 9 time(s).You cannot view/download attachments. Try to login or register.
