Re-use trial before upgrade
Hello, I currently own a 4k version and think about upgrading to pro version. Before upgrading, I want to check, that it fits my requirements. I already had a trial version in the past. Is it possible to use the trial again ? Best regards Thomas
Joined: 11/23/2020(UTC) Posts: 251  Location: Wichita Thanks: 14 times Was thanked: 32 time(s) in 28 post(s)
Originally Posted by: thos-berlin  Hello, I currently own a 4k version and think about upgrading to pro version. Before upgrading, I want to check, that it fits my requirements. I already had a trial version in the past. Is it possible to use the trial again ? Best regards Thomas Buy a one month subscription to the 4k version using the new licensing terms, add more months if you need more time. Once completed you can decide whether the 4k version is what you want to upgrade to and you can occasionally activate the other subscription again if you ever need another copy for a short term project.
