Stream Fail - FFMPEG and Audio?
Joined: 1/19/2022(UTC) Posts: 6   Location: Indiana Thanks: 1 times
We attempted a stream of a high school event this evening and had no success. We were trying to connect to our YouTube channel, and it kept saying that the audio I/O failed. It presented with this log. It looks like for whatever reason it doesn't like the audio settings we had for the event, but they're no different than any we've had in the past.
Guidance and diagnosis are appreciated!
--- FFMPEG1.Exited ffmpeg started on 2024-04-24 at 18:23:44 Report written to "C:\ProgramData\vMix\streaming\streaming1 20240424-182344.log" ffmpeg version 3.3.git Copyright (c) 2000-2017 the FFmpeg developers built with gcc 4.8.1 (rev2, Built by MinGW-W64 project) configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-nvenc --cpu=i686 libavutil 55. 76.100 / 55. 76.100 libavcodec 57.106.101 / 57.106.101 libavformat 57. 82.101 / 57. 82.101 libavdevice 57. 8.101 / 57. 8.101 libavfilter 6.105.100 / 6.105.100 libswscale 4. 7.103 / 4. 7.103 libswresample 2. 8.100 / 2. 8.100 libpostproc 54. 6.100 / 54. 6.100 Guessed Channel Layout for Input Stream #0.1 : stereo Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio': Duration: N/A, start: 300.288000, bitrate: 1536 kb/s Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1920x1080, 59.94 fps, 59.94 tbr, 10000k tbn, 10000k tbc Stream #0:1: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s [tcp @ 050be1c0] TCP Buffer has been set to 14390272 bytes rtmp://a.rtmp.youtube.com/live2/rp9a-tf9v-qbq2-c1cm-6w9g1: I/O error
Joined: 8/2/2013(UTC) Posts: 1,096   Location: Fairhope, Alabama USA Thanks: 588 times Was thanked: 202 time(s) in 168 post(s)
Found this on this forum. vMix I/O errorDon't think this is an audio thing. Looks more like a credentials thing or even an internet thing. - Tom
