90° Rotate on a List Input - Bug?
Joined: 5/10/2020(UTC) Posts: 104   Location: Sacramento, California Thanks: 13 times Was thanked: 5 time(s) in 5 post(s)
Starting to do some experimenting for my first-ever vertical (9:16) stream. I have some videos which are shot in the vertical format which need to be rotated 90° in the position menu. (Thanks for the quick 90° button!) This works just fine. But when I put the videos into a list input, the 90° button works until you change to a different video in the list, then it goes back to normal. I can get around this by manually rotating and resizing, but what is the correct amount to Z rotate? It looks like it's -1.57??? I know I'm not good a geometry, but I can't figure out why that's the number (or is it?)
