Can someone PLEASE help Me!
Joined: 10/3/2021(UTC) Posts: 61  Location: Wichita Falls, TX Thanks: 6 times Was thanked: 3 time(s) in 3 post(s)
I have been getting this now over and over. internet looks fine in ping plotter pro with no packet loss, gitter, and latency around 20ms. However I cant push even 6mbps upload to YouTube or Uscreen anymore. Was fine lsat week. Speed tests look fine as well from speedtest.net and fast.com.
[dshow @ 02af7c60] real-time buffer [vMix Video YV12] [video input] too full or near too full (65% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02af7c60] real-time buffer [vMix Video YV12] [video input] too full or near too full (63% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02af7c60] real-time buffer [vMix Video YV12] [video input] too full or near too full (72% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02af7c60] real-time buffer [vMix Video YV12] [video input] too full or near too full (68% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02af7c60] real-time buffer [vMix Video YV12] [video input] too full or near too full (70% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02af7c60] real-time buffer [vMix Video YV12] [video input] too full or near too full (75% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02af7c60] real-time buffer [vMix Video YV12] [video input] too full or near too full (77% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02af7c60] real-time buffer [vMix Video YV12] [video input] too full or near too full (80% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02af7c60] real-time buffer [vMix Video YV12] [video input] too full or near too full (82% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02af7c60] real-time buffer [vMix Video YV12] [video input] too full or near too full (85% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02af7c60] real-time buffer [vMix Video YV12] [video input] too full or near too full (89% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02af7c60] real-time buffer [vMix Video YV12] [video input] too full or near too full (92% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02af7c60] real-time buffer [vMix Video YV12] [video input] too full or near too full (94% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02af7c60] real-time buffer [vMix Video YV12] [video input] too full or near too full (94% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02af7c60] real-time buffer [vMix Video YV12] [video input] too full or near too full (94% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02af7c60] real-time buffer [vMix Video YV12] [video input] too full or near too full (94% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02af7c60] real-time buffer [vMix Video YV12] [video input] too full or near too full (94% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02af7c60] real-time buffer [vMix Video YV12] [video input] too full or near too full (94% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02af7c60] real-time buffer [vMix Video YV12] [video input] too full or near too full (94% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02af7c60] real-time buffer [vMix Video YV12] [video input] too full or near too full (94% of size: 128000000 [rtbufsize parameter])! frame dropped!
@ cody@raceontexas.comhttps://www.vmix.com/kno...mes-show-orange-or-amberI suspect either internet congestion or your ISP may be throttling you back for some reason (speed tests can be misleading as they are for relatively short periods of time compared to the extended requirements of a Live Event Stream and some ISPs are known to throttle back on internet "hogs" after a period of time so that they can "effectively" accommodate other customers). Ice
This has just started in the last week now and never been a problem before. It also happens 5 minutes in or 2 hours in, there is no rhyme or reason to it. I am testing more also, but it seems after I unchecked High Performance Output it has stopped.
Joined: 12/3/2024(UTC) Posts: 6  Location: Canary Islands
Originally Posted by: cody@raceontexas.com  This has just started in the last week now and never been a problem before. It also happens 5 minutes in or 2 hours in, there is no rhyme or reason to it. I am testing more also, but it seems after I unchecked High Performance Output it has stopped. Please could you give me more information about your solution? Did you simply turn off the high performance of Vmix or power consumption on your laptop? It has since been fixed and has not failed again? Thank you very much.
