kitter
#1 Posted : Monday, March 4, 2024 10:26:24 PM(UTC)
kitter
Czech Republic
when a camera has a loose connection, or the camera has "walk-around" wireless connection and gets oftenly turned off, vMix stops replay recording of those cameras as soon as they lose signal.
When it's time to delete old recordings due to disk space, vMix seems only to delete "regularily ended" recordings, and leaves those shorter ones still on disk.
You can tell by the directory listing from our production vMix machine. Newest files on the bottom are ~33GB each. On the top, the oldest files are only short "crumbs", that didn't get deleted. You can also note the camera numbering at the end of the file names (-1, -2, -3, etc.)
Can this be fixed please? This issue silently fills up the disk space without anyone noticing. We don't use "Delete replay cache" button because it is not needed, it is believed it gets deleted on its own according to the disk space (Automatically delete...when disk space is low.).
vMix 26.0.0.45
Thanks, Jakub
Code:
26.01.2024  18:21        10 066 876 stream-20240126-182145-6.avi
26.01.2024  18:28     9 408 460 756 stream-20240126-182218-6.avi
26.01.2024  18:34     7 425 924 952 stream-20240126-182904-6.avi
26.01.2024  18:39       144 328 604 stream-20240126-183907-6.avi
26.01.2024  18:39       154 999 822 stream-20240126-183924-6.avi
26.01.2024  18:54    20 710 159 418 stream-20240126-183940-6.avi
26.01.2024  19:12     2 863 606 644 stream-20240126-190953-6.avi
26.01.2024  19:12       791 234 244 stream-20240126-191205-6.avi
26.01.2024  19:14     2 074 523 076 stream-20240126-191254-6.avi
26.01.2024  19:19     1 366 239 252 stream-20240126-191817-6.avi
26.01.2024  19:19       597 564 044 stream-20240126-191923-6.avi
26.01.2024  19:20       162 218 772 stream-20240126-192001-6.avi
26.01.2024  19:20       367 734 514 stream-20240126-192017-6.avi
26.01.2024  19:21       561 293 802 stream-20240126-192039-6.avi
26.01.2024  19:22       431 504 922 stream-20240126-192134-6.avi
26.01.2024  19:22         4 149 658 stream-20240126-192207-6.avi
26.01.2024  19:22       156 930 626 stream-20240126-192218-6.avi
26.01.2024  19:23       512 699 186 stream-20240126-192240-6.avi
26.01.2024  19:23       218 959 556 stream-20240126-192323-6.avi
26.01.2024  19:24       232 182 120 stream-20240126-192345-6.avi
26.01.2024  19:24        25 846 130 stream-20240126-192407-6.avi
26.01.2024  19:24        87 273 532 stream-20240126-192418-6.avi
26.01.2024  19:24       395 309 084 stream-20240126-192435-6.avi
26.01.2024  19:26     1 688 551 146 stream-20240126-192502-6.avi
26.01.2024  19:27     1 428 694 176 stream-20240126-192640-6.avi
26.01.2024  19:31     4 879 862 784 stream-20240126-192752-6.avi
26.01.2024  19:31       154 390 340 stream-20240126-193143-6.avi
26.01.2024  19:34     3 520 037 528 stream-20240126-193159-6.avi
26.01.2024  19:38     4 870 483 906 stream-20240126-193443-6.avi
26.01.2024  19:38        15 732 296 stream-20240126-193839-6.avi
26.01.2024  19:38        18 245 958 stream-20240126-193849-6.avi
26.01.2024  19:39         9 737 852 stream-20240126-193900-6.avi
26.01.2024  19:39        31 600 084 stream-20240126-193922-6.avi
26.01.2024  19:39        37 770 390 stream-20240126-193933-6.avi
26.01.2024  19:39        85 694 550 stream-20240126-193944-6.avi
26.01.2024  19:40        51 037 698 stream-20240126-194001-6.avi
26.01.2024  19:40       106 468 258 stream-20240126-194012-6.avi
26.01.2024  19:40       343 438 638 stream-20240126-194022-6.avi
27.01.2024  16:19       222 365 302 stream-20240127-161859-5.avi
27.01.2024  16:35    25 463 553 702 stream-20240127-161916-3.avi
27.01.2024  16:35    25 762 982 336 stream-20240127-161921-5.avi
10.02.2024  18:13    12 509 211 482 stream-20240210-180459-3.avi
15.02.2024  19:07        79 816 514 stream-20240215-190733-3.avi
15.02.2024  19:09       130 499 732 stream-20240215-190749-3.avi
15.02.2024  19:09        87 483 550 stream-20240215-190906-3.avi
15.02.2024  19:25    27 796 378 658 stream-20240215-190928-3.avi
23.02.2024  19:56       617 974 734 stream-20240223-194242-9.avi
24.02.2024  17:11     4 084 950 202 stream-20240224-170813-7.avi
24.02.2024  17:21    14 477 555 374 stream-20240224-171113-7.avi
24.02.2024  18:08    27 276 474 106 stream-20240224-175133-3.avi
24.02.2024  18:00     6 958 741 422 stream-20240224-175502-7.avi
24.02.2024  18:08    11 753 546 474 stream-20240224-180030-7.avi
29.02.2024  18:24     3 074 964 786 stream-20240229-180729-6.avi
29.02.2024  18:21    17 625 572 450 stream-20240229-180940-3.avi
29.02.2024  18:41    21 100 881 996 stream-20240229-182416-6.avi
29.02.2024  19:21    31 705 548 726 stream-20240229-190108-1.avi
29.02.2024  19:21    32 132 611 028 stream-20240229-190108-2.avi
29.02.2024  19:21    30 968 495 364 stream-20240229-190108-3.avi
29.02.2024  19:21    33 539 822 152 stream-20240229-190108-4.avi
29.02.2024  19:21    29 976 675 672 stream-20240229-190108-5.avi
29.02.2024  19:21    28 828 538 766 stream-20240229-190108-6.avi
29.02.2024  19:21       927 892 774 stream-20240229-190108-9.avi
29.02.2024  19:41    32 165 471 930 stream-20240229-192108-1.avi
29.02.2024  19:41    32 491 179 356 stream-20240229-192108-2.avi
29.02.2024  19:41    31 764 085 124 stream-20240229-192108-3.avi
29.02.2024  19:41    32 668 973 090 stream-20240229-192108-4.avi
29.02.2024  19:41    30 138 912 088 stream-20240229-192108-5.avi
29.02.2024  19:41    31 044 846 808 stream-20240229-192108-6.avi
29.02.2024  19:41       927 892 774 stream-20240229-192108-9.avi
29.02.2024  19:50    14 274 231 284 stream-20240229-194108-1.avi
29.02.2024  19:50    14 475 988 456 stream-20240229-194108-2.avi
29.02.2024  19:50    15 605 638 160 stream-20240229-194108-3.avi
29.02.2024  19:50    15 814 036 358 stream-20240229-194108-4.avi
29.02.2024  19:50    15 337 683 304 stream-20240229-194108-5.avi
29.02.2024  19:50    12 740 602 054 stream-20240229-194108-6.avi
29.02.2024  19:50       455 475 830 stream-20240229-194108-9.avi
02.03.2024  17:21    33 030 275 984 stream-20240302-170111-1.avi
02.03.2024  17:21    32 714 603 442 stream-20240302-170111-2.avi
02.03.2024  17:21    32 340 281 636 stream-20240302-170111-3.avi
02.03.2024  17:21    32 383 856 748 stream-20240302-170111-4.avi
02.03.2024  17:21    33 336 067 224 stream-20240302-170111-5.avi
02.03.2024  17:21       927 892 774 stream-20240302-170111-9.avi
02.03.2024  17:41    32 175 797 740 stream-20240302-172111-1.avi
02.03.2024  17:41    33 532 863 930 stream-20240302-172111-2.avi
02.03.2024  17:41    32 025 557 950 stream-20240302-172111-3.avi
02.03.2024  17:41    33 195 699 888 stream-20240302-172111-4.avi
02.03.2024  17:41    33 972 932 630 stream-20240302-172111-5.avi
02.03.2024  17:41       927 892 774 stream-20240302-172111-9.avi
02.03.2024  18:01    32 395 606 972 stream-20240302-174111-1.avi
02.03.2024  18:01    33 198 048 502 stream-20240302-174111-2.avi
02.03.2024  18:01    32 166 231 610 stream-20240302-174111-3.avi
02.03.2024  18:01    32 470 063 598 stream-20240302-174111-4.avi
02.03.2024  18:01    33 579 679 016 stream-20240302-174111-5.avi
02.03.2024  18:01       927 892 774 stream-20240302-174111-9.avi
02.03.2024  18:21    33 006 461 122 stream-20240302-180111-1.avi
02.03.2024  18:21    32 646 328 718 stream-20240302-180111-2.avi
02.03.2024  18:21    32 524 557 724 stream-20240302-180111-3.avi
02.03.2024  18:21    32 214 266 678 stream-20240302-180111-4.avi
02.03.2024  18:21    33 410 434 410 stream-20240302-180111-5.avi
02.03.2024  18:21       927 916 238 stream-20240302-180111-9.avi
02.03.2024  18:48    31 613 729 506 stream-20240302-182111-1.avi
02.03.2024  18:41    32 918 893 456 stream-20240302-182111-2.avi
02.03.2024  18:48    31 330 230 402 stream-20240302-182111-3.avi
02.03.2024  18:48    30 034 904 358 stream-20240302-182111-4.avi
02.03.2024  18:41    33 560 004 184 stream-20240302-182111-5.avi
02.03.2024  18:41       927 892 774 stream-20240302-182111-9.avi
02.03.2024  18:48        61 457 522 stream-20240302-184111-2.avi
02.03.2024  18:48     3 452 046 094 stream-20240302-184111-5.avi
02.03.2024  18:46       232 700 694 stream-20240302-184111-9.avi
02.03.2024  18:48       100 190 590 stream-20240302-184618-9.avi
