Feature Requests
Zoom: Option to disable automatic reconnect
Joined: 2/18/2014(UTC) Posts: 1,843 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
It seems that when vMix opens a Preset that was saved with Zoom connected, or relaunched after a settings change, Zoom automatically connects to the meeting. While this is sometimes useful, I am not confident in that such behaviour is always desired.
By now we have done a number of real productions with Zoom in vMix. In general it has been working very well, and being much easier than running Zoom separately. But, for some of these productions we forgot to disconnect before saving the Preset. Sometimes the reconnection was more annoying than serious. In a couple of cases it caused some problems. Especially as we do not get any clear indication of that Zoom is reconnecting, or is connected. Instead, the operator must specifically check if "Click here to connect" is shown on the Zoom Inputs previews.
Therefore, I request an option to disable this automatic reconnection. Perhaps as a checkbox setting in the Zoom setup window.
Thanks.
Joined: 5/9/2020(UTC) Posts: 17  Location: Cologne Was thanked: 3 time(s) in 2 post(s)
Joined: 10/12/2018(UTC) Posts: 4   Location: Kyiv, Ukraine
Joined: 8/16/2019(UTC) Posts: 355  Thanks: 80 times Was thanked: 24 time(s) in 19 post(s)
Feature Requests
