Modifie an After Effect project from VMix
Hi, I'm looking for a solution to modifie an After Effect project directly in VMix without exporting it every time. Is it even possible ?
I know it's possible to work on the title from After Effect and input it in VMix via NDI. But I want my operator able to edit it directly from VMix and not from After Effect.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Emilion  Hi, I'm looking for a solution to modifie an After Effect project directly in VMix without exporting it every time. Is it even possible ?
Thanks Nope, why not GT titles ?
Because I work for a TV Channel and we need to use After Effect to have the same titles in post production.
Thanks: 4 times Was thanked: 2 time(s) in 2 post(s)
GT needs a timeline for all payers as well as a pause point markers on the timeline to represent pages and an option to select a time range as loop after in animation effect. That would be really cool to make the app kickass
Joined: 10/31/2020(UTC) Posts: 205  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
Can't do it from vMix directly. In fact, I don't believe vMix can open an AE project at all. I think it can only open a rendered video file exported from AE.
However, I believe NewBlue FX can import an After Effects project, and make live edits from within NewBlue FX. It would output to vMix via NDI.
