ASLIVE MEDIA
#1 Posted : Thursday, February 8, 2024 7:32:14 AM(UTC)
ASLIVE MEDIA
Poland
Hello, I have layers ready in GT for your questions. I want to change the background color from blue to green at the end - correct answer. I want to make a shortcut to change this background
I used to do this - but either I forgot or something changed.
Will it help find a solution?
#2 Posted : Thursday, February 8, 2024 7:44:16 AM(UTC)
LOL oh your serious LOL
things havent changed but things were added ;-)
one can still use images as background to change (SetImage or visible/invisible) or the newer SetColor (of shapes)
or whatch one of the many vMix Tutorial videos to refresh your memory like this one:
ASLIVE MEDIA
#3 Posted : Thursday, February 8, 2024 7:37:37 PM(UTC)
ASLIVE MEDIA
Poland
Thank you, you refreshed the topic for me. Everything works except one thing :] I change the color, but to create non-standard graphics you have to use Photoshop. And after importing to GT, unfortunately it only sees it as a Bitmap. So here I had to create a "rectangle" in GT and apply it to the graphic. I guess it's not possible to change the properties of an imported file from PS to GT so that it is seen as a "rectangle"?
The shortcuts work great.
