briandaly
#1 Posted : Wednesday, December 24, 2014 7:31:01 PM(UTC)
briandaly
I have an Intel i7 4770k processor with 16GB of Ram on a Gigabyte GA-Z87-D3HP motherboard and vMix 4K. I use 1 X Blackmagic Decklink SDI Card and 2 X Decklink Minirecorder cards that work with Livestream and Media Express software. Attached please find screen capture image of the way the computer goes. I cannot recover anything and i'm forced to reset the Computer in order to use it again. Please advise me on what I should do to resolve this issue. Regards, Brian Daly Cavan Television
Len56
#2 Posted : Thursday, December 25, 2014 10:52:14 AM(UTC)
Len56
Hi Brian,
What graphic are you using and have you got the latest drivers installed for your BlackMagic cards and graphic card.
I am using a BlackMagic TV Studio and a Intensity Pro card and a PC with an i7 processer and 16GB RAM and have no problems like you are finding so it could be down to your graphics card or outdated drivers.
Also are you recording to Media Express to the same hard drive as you running vMix, if so that could be the problem, it is using to much of your CPU.
I cannot see any screen capture attached.
By the way Happy Christmas.
