Feature Requests
Color Correction on Relay Exports
Joined: 4/28/2019(UTC) Posts: 12  Location: Salem, Oregon Was thanked: 2 time(s) in 2 post(s)
Currently, when color corrections are applied to an input that is set as a replay input, those corrections are not applied during a replay clip export. They are applied during replay playout, but not during export. When exporting replay clips, the resulting files should look as they do in the replay interface. So, applying the color corrections during replay clip export.
Joined: 9/21/2021(UTC) Posts: 9  Location: Elektrėnai Was thanked: 1 time(s) in 1 post(s)
Joined: 11/14/2012(UTC) Posts: 366  Location: Finland Thanks: 235 times Was thanked: 25 time(s) in 23 post(s)
Feature Requests
