Hardware Compatibility
StarTech SVID2USB232 on Windows 11 Quality
Joined: 1/31/2024(UTC) Posts: 1  Location: Charlotte, NC
Hello, I have upgraded from a Win 7 system to a Dell XPS 8950 running Windows 11. The vMix was down level, but am running the latest now. The old system was using an old StarTech capture device that only supported up to Windows 8. I purchased a SVID2USB232 for the new system. I was not aware of the compatibility page at the time, but the device says it is DirectShow compatible. The picture was good on the old system, but is poor on the new one. The camera is a Sony EVI-D70 with S-Video connection. I have my input configured as: Camera: USB 2828x Device Input: Default Resolution: 720x480 Frame Rate: NTSC 59.94i
I have tried many combinations, but this seems to be the best. Do you think this is the best I can do or do you have any ideas on what the problem might be?
Thanks to all, Bob
Hello. Until end 2021 i was working in windows 7 and adapters like the one you have. Once i moved to new pc and windows 10 all these adapters became a piece of crap. As i see it from my experience "you cant teach new tricks to an old dog"..
