mct
#1 Posted : Sunday, January 28, 2024 12:39:24 PM(UTC)
mct
When using Zoom, the active speaker doesn't work. The participant source stays on the host camera when set to default, regardless of who is speaking.
No pin or spotlight is set. Anyone in the zoom app or zoom web sees the cameras changing as per the usual active speaker, but not in vmix.
We tried with both an HD licence and a Pro licence.
#2 Posted : Sunday, January 28, 2024 12:49:17 PM(UTC)
Was thanked: 4719 time(s) in 1617 post(s)
This is expected behaviour.
To explain why, vMix only has access to raw audio/feeds of participants that need to be selected manually.
There is no "active speaker" feed available.
So default is the first participant in the meeting.
It is not possible to dynamically change this, as this would require multiple recordings to be started and stopped, sometimes many a second
that would become unreliable and offer poor performance.
As a result, you will need to manually assign participants to separate Zoom inputs in vMix.
mct
#3 Posted : Sunday, January 28, 2024 1:20:26 PM(UTC)
mct
Thank you Martin,
That explains it!
spinfold
#4 Posted : Sunday, January 28, 2024 6:16:57 PM(UTC)
spinfold
Was thanked: 14 time(s) in 14 post(s)
You can simulate Active Speaker with the new triggers - set a trigger for "when this person is speaking on Zoom, cut this source to output".
mvoccola
#5 Posted : Thursday, October 10, 2024 1:13:39 AM(UTC)
mvoccola
ZoomISO figured this out...
WaltG12
#6 Posted : Thursday, October 10, 2024 7:44:01 AM(UTC)
WaltG12
So did vMix, as was pointed out in the comment you're replying to.
ayoung
#7 Posted : Tuesday, December 10, 2024 3:59:51 AM(UTC)
ayoung
Nice idea. Could you explain what trigger you would use for this? 'OnAudioMeterDBx' for example?
#8 Posted : Tuesday, December 10, 2024 9:23:01 PM(UTC)
@ ayoung
"OnZoomActiveSpeaker"
It is in the Trigger dropdown list from vMix 27 onward.
Much of that is explained here in this vMix Tutorial video (at 18:30):
mct
#9 Posted : Sunday, December 15, 2024 10:42:16 AM(UTC)
mct
It is not the same thing. The idea is to have just one input, to save on resources, that does the active speaker like zoom does.
All alternative products have it: ZoomISO, Zoom Bridge, Zoom Rooms (Ok yes it's zoom but NDI and Dante outputs from it), etc.
WaltG12
#10 Posted : Sunday, December 15, 2024 1:00:10 PM(UTC)
WaltG12
What resources do you think you'd be saving by having vMix do the exact same thing these triggers are doing, but behind the scenes?
mct
#11 Posted: : Monday, December 16, 2024 12:35:52 AM(UTC)
mct
You don't need to add all speakers as 1080p inputs in vmix, just one zoom input, saving on a lot of processing power. The sdk plugin simply gives you the active speaker zoom has internal to it. The speaker who is not in active speaker is not being generated at 1080p, but a much lower resolution until it becomes active. Yes there is sometimes a short resolution ramp up after transition, but very workable.
We've done events with 12-15 speakers, using active speakers, you have nothing to program or pre-set. The "active speaker" is being done by zoom and not the app you're using (vmix in this case). Setting 12-15 speakers for the event would be very demanding and harder to manage, when you don't know which one is jumping in to speak during a question period.
That highlights the other issue with the vmix plugin, which goes to black when changing cameras in the same input, which other apps simply give you the current resolution of the speaker and then ramps it up to the max resolution when it becomes active. Which gives smoother transitions between speakers on the same input, instead of going to black when live.
ayoung
#12 Posted : Wednesday, February 19, 2025 6:54:01 PM(UTC)
ayoung
This is a superb solution. I've implemented it this week and discovered a heartbreaking limitation - Zoom sends no Active Speaker info to vMix when you Spotlight any meeting participant. Which makes sense, but is frustrating as our workflow requires spotlighting. Pinning a participant won't achieve the same.
So I may implement 'OnAudioMeterDBx' after all...
