pixhelia
#1 Posted : Monday, January 22, 2024 6:41:23 PM(UTC)
pixhelia
Hello, first of all, sorry for my bad English.
I had two issues in the last streaming.
When I finish the transmission and stop the recording, it does not appear in the folder, however the log file it's just there. I'll pass it on to you in case you are able to help me.
21/01/2024 16:56:52, Version: 26.0.0.45 x64
21/01/2024 16:56:52, Size: 1920x1080
21/01/2024 16:56:52, System: PAL 50p
21/01/2024 16:56:52, Codec: H264
21/01/2024 16:56:52, Format: UYVY 16 1498831189
21/01/2024 16:56:52, AudioDevice: vMix Audio
21/01/2024 16:56:52, AudioFormat: 48000 Hz 16 Bit 2 Channels
21/01/2024 16:56:52, AudioDelay: 0
21/01/2024 16:56:52, RestartInterval: 0
21/01/2024 16:56:52, Buffers: 10
21/01/2024 16:56:52, BitRate: 6 Mbps
21/01/2024 16:56:52, AudioBitRate: 128 Kbps
21/01/2024 16:56:52, StartRecording
21/01/2024 18:56:18, StopRecording
21/01/2024 18:56:18, Duration: 01:59:26
21/01/2024 18:56:18, Frames: 357955
21/01/2024 18:56:18, DroppedFrames: 359
21/01/2024 18:56:18, DueToSourceFrameRate: 359
21/01/2024 18:56:18, DueToHardDiskOrCPU: 0
21/01/2024 18:56:18, DroppedSamples: 16
21/01/2024 18:56:18, MissedSamples: 16
21/01/2024 18:56:18, SyncedSamples: 0
21/01/2024 18:56:18, AudioOffset: 0
21/01/2024 18:56:18, AudioDelay: 0
21/01/2024 18:56:18, AudioEngine
21/01/2024 18:56:18, Running: True
21/01/2024 18:56:18, SampleRate: 48000hz 16 Bit
21/01/2024 18:56:18, MixingErrors: 0
21/01/2024 18:56:18, Streams
21/01/2024 18:56:18, Mixer
21/01/2024 18:56:18, Samples: 512028
21/01/2024 18:56:18, Dropped: Read 0 Write 0
21/01/2024 18:56:18, Latency: 0 ms
21/01/2024 18:56:18, Errors: 0
21/01/2024 18:56:18, Headphones
21/01/2024 18:56:18, Samples: 512013
21/01/2024 18:56:18, Dropped: Read 13 Write 2
21/01/2024 18:56:18, Latency: 40 ms
21/01/2024 18:56:18, VLC
21/01/2024 18:56:18, Samples: 477252
21/01/2024 18:56:18, Dropped: Read 104 Write 0
21/01/2024 18:56:18, Latency: 60 ms
21/01/2024 18:56:18, TargetLatency: 40 ms
21/01/2024 18:56:18, Resampled: 620/380
21/01/2024 18:56:18, Replay
21/01/2024 18:56:18, Samples: 27754
21/01/2024 18:56:18, Dropped: Read 150 Write 0
21/01/2024 18:56:18, Latency: 220 ms
21/01/2024 18:56:18, TargetLatency: 200 ms
21/01/2024 18:56:18, Resampled: 920/20
21/01/2024 18:56:18, Samples: 8
21/01/2024 18:56:18, Latency: 160 ms
21/01/2024 18:56:18, Resampled: 0/0
21/01/2024 18:56:18, DirectShow
21/01/2024 18:56:18, Samples: 5951
21/01/2024 18:56:18, Latency: 1020 ms
21/01/2024 18:56:18, Samples: 53
21/01/2024 18:56:18, Latency: 1060 ms
pixhelia
#2 Posted : Monday, January 22, 2024 6:46:03 PM(UTC)
pixhelia
On the other hand, several times the streaming turned yellow, and in the online recording there is quite a bit of audio lag after one hour and 35 minutes.
I hope you can help me to find the problem.Thank You
26.0.0.45 - WINDOWS - 21/01/2024 10:10:46
Error disabling WindowsUpdate: vMix.vMixServiceException: vMix Service Not Ready
en vMix.vMixServiceClient.Startup()
en qzzzzzr.w()
26.0.0.45 - WebServer.ClientError - 21/01/2024 10:11:19
System.IO.IOException: No se pueden leer los datos de la conexión de transporte: Se ha anulado una conexión establecida por el software en su equipo host. ---> System.Net.Sockets.SocketException: Se ha anulado una conexión establecida por el software en su equipo host
en System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
en System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size)
--- Fin del seguimiento de la pila de la excepción interna ---
en rzzzzzu.a(String a, Byte[] a, String a, NameValueCollection a, String a, Stream a, Boolean a)
en rzzzzzu.b(IPEndPoint a, IPEndPoint a, String a, Uri a, StringBuilder a, Stream a, NameValueCollection a, Boolean a)
en rzzzzzu.c(Object a, SocketAsyncEventArgs a)
26.0.0.45 - WINDOWS - 21/01/2024 12:34:40
en qzzzzzr.w()
26.0.0.45 - WebServer.ClientError - 21/01/2024 12:38:35
26.0.0.45 - WINDOWS - 21/01/2024 16:05:36
en qzzzzzr.w()
26.0.0.45 - WebServer.ClientError - 21/01/2024 16:06:32
26.0.0.45 - PerformanceMonitor - 21/01/2024 17:48:45
Render Time limit warning. > 30 ms.
26.0.0.45 - PerformanceMonitor - 21/01/2024 17:48:53
Render Time warning has ended. Was > 30 ms for 12 seconds.
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:06:13
0: 37,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:06:24
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:06:25
0: 49,
0: 49,
0: 48,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:06:30
0: 49,
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:06:31
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:06:32
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:06:33
0: 39,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:10:09
0: 12,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:10:20
0: 49,
0: 49,
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:10:21
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:10:29
0: 49,
0: 49,
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:14:25
0: 19,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:14:41
0: 49,
0: 49,
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:16:25
0: 42,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:16:34
0: 49,
0: 49,
0: 49,
0: 49,
0: 49,
0: 37,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:16:35
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:16:37
0: 49,
0: 27,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:16:41
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:16:42
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:16:43
0: 40,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:16:54
0: 18,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:16:55
0: 35,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:16:56
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:16:58
0: 49,
pixhelia
#3 Posted : Monday, January 22, 2024 6:47:12 PM(UTC)
pixhelia
0: 7,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:18:54
0: 28,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:19:05
0: 49,
0: 49,
0: 49,
0: 49,
0: 49,
0: 36,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:19:18
0: 40,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:19:24
0: 49,
0: 49,
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:21:24
0: 48,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:21:33
0: 49,
0: 49,
0: 49,
0: 49,
0: 49,
0: 39,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:21:34
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:21:43
0: 49,
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:21:45
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:23:04
0: 28,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:23:08
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:23:11
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:23:15
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:23:16
0: 49,
0: 49,
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:23:17
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:23:19
0: 49,
0: 27,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:23:33
0: 27,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:23:34
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:24:42
0: 36,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:24:46
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:24:47
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:24:53
0: 49,
0: 49,
0: 49,
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:24:59
0: 49,
0: 49,
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:26:56
0: 35,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:27:03
0: 49,
0: 49,
0: 49,
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:27:15
0: 7,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:27:16
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:27:24
0: 49,
0: 49,
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:28:49
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:28:57
0: 49,
0: 49,
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:28:58
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:29:07
0: 49,
0: 49,
0: 49,
0: 49,
0: 49,
0: 21,
26.0.0.45 - UpdateVirtualCaptureSettings0 - 21/01/2024 18:29:15
Skipped due to Virtual Device open in another application
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:31:47
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:31:56
0: 49,
0: 49,
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:31:57
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:31:58
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:31:59
0: 22,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:32:16
0: 45,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:32:19
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:33:27
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:33:30
0: 49,
0: 49,
0: 41,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:33:37
0: 49,
0: 49,
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:33:38
0: 28,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:33:46
0: 46,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:33:47
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:33:48
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:33:51
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:34:45
0: 6,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:34:46
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:34:51
0: 49,
0: 49,
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:34:56
0: 49,
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:35:02
0: 18,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:35:06
0: 49,
0: 49,
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:35:07
0: 46,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:35:08
0: 24,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:35:09
0: 49,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:35:11
0: 8,
26.0.0.45 - Replay.RecordBuffers - 21/01/2024 18:35:14
0: 49,
