TL68
#1 Posted : Thursday, January 18, 2024 6:34:52 PM(UTC)
TL68
Sweden
Hi!
Trying to use a spreadsheet (Sheets) for as much of text and data for graphics etc as possible (as a vMix dummy); I ran in to a bit of trouble when I wanted to use a time in sheets to set the time which a countdown uses to count down to.
I solved this (with great help from the forum) by creating the the correct string for countdown to in sheets by som combining of cell data.
Of course this works but it would be neat if there was funktionality within the title object to fetch the time directly from a data source. For example into a dedicated field in the title editor.
Cheers!
T
