LinksLive
#1 Posted : Monday, January 15, 2024 10:06:46 AM(UTC)
LinksLive
Canada
I have a void max system, for video replay. It is currently setup for 4 cameras in and 1 channel out. All the system is used for is replay. The system replay play out was working well for several hours then near the end of the show the replays started to jump mid clip to the next clip.
The issue persisted the rest of the show.
The operator check the cpu and gpa usage and they were very low at the time.
He also did a data purge when that didn’t work he rebooted the system and recalled the file the issue was still present.
We were recording 1080p 29.97
The operator said he has seen the same issue on other systems and that it started happening some time over the summer
Has anyone experienced this?
System is
i9 13th 13900kf, 64GB ram
2TB nvme system drive
Two, 2TB nvme striped as one 4TB drive
2TB working drive for file storage
Nvidia 2060TI 6GB
2 decklink duo 2 cards
