SethLT
#1 Posted : Friday, January 12, 2024 5:26:31 AM(UTC)
SethLT
As the title states, I use triggers, A LOT. Sometimes I am making multiple triggers per clips such as b-roll where I could have up to 100 items. I often utilize the "copy from" feature, which does save time, but if I need to add a new trigger to all of those items, I am then going through individually and adding it. If possible, a copy/paste line in the triggers would be amazing.
Also, this is a bit different from the request but I often set a trigger to do something to it's own clip. When I copy, it copies from the previous source and then I need to drop down and change it to the current. Maybe for input sources we could add a "self" or something that would copy easier.
Thank you!
