TL68
#1 Posted : Wednesday, January 10, 2024 10:12:16 PM(UTC)
TL68
Sweden
Hi!
I got a couple of questions regarding instant replay and file storage, that I have not been able to find answers to in documentation or the forum.
1. Is there a way to adjust vMix limit for when it detects disk space is low to auto delete prior videos? Right now it seems as if the limit is around 10gb which i find being a bit low if you like me have to store replay
files on the same partition as windows runs on (yes I know this is not optimal but it is what I have to deal with atm).
2. Is there a way to create a shortcut or custom command to run the "Delete All" function which has a button in the Instant Replay configuration panel?
Thanks in advance for any input regarding this!
kross
#2 Posted : Saturday, January 13, 2024 3:10:01 PM(UTC)
kross
Was thanked: 46 time(s) in 45 post(s)
If you absolutely must put replays on the same drive as Windows, then at least create a separate partition for replays. Then vMix can fill up the replay partition and you won't have to worry about it affecting Windows or anything else.
EaseUS Partition Master free trial should be able to resize your Windows partition to make room for a new replay partition.
thanks 1 user thanked kross for this useful post.
TL68 on 1/15/2024(UTC)
