SDKUCSS
#1 Posted : Wednesday, January 3, 2024 6:06:58 AM(UTC)
SDKUCSS
Question regarding the "export" of Settings. If I open up "settings" you then see on the left hand side of the windows all settings: display, options, recording, shortcuts, activators... etc. I then highlight from the list of settings, the "shortcuts" option, then I click "export" and save the file. What exactly is "exported" during this process" Are all subgroups listed in the "settings" section exported? If I highlight only "shortcuts" are only the shortcuts exported? Same question regarding "import" are all settings "imported? or just the settings you want, such as shortcuts, activators, etc?
