swamiforlife2
#1 Posted : Friday, December 8, 2023 1:26:28 PM(UTC)
swamiforlife2
I am using vmix 26 on a intel i7 10700k cpu with 32gb of memory.
When i add local sources like video files and photos memory usage is 100%. There are over 350 of these sources.
Is this normal behavior for Vmix?
I dont have any 3rd party anti virus installed.
I am not streaming anything, just using Vmix as a method to playback video files that are feed to the vision mixer.
The high memory usage make vmix very unstable and it crashes a lot.
What could be the problem?
#2 Posted : Friday, December 8, 2023 2:56:13 PM(UTC)
Consider using list input
nikosman88
#3 Posted : Friday, December 8, 2023 10:32:14 PM(UTC)
nikosman88
Greece
Yes it is normal because of how the gpu memory work between gpu and vmix. What model is your GPU? If you have a rtx 30x and up, see if you can enable the resizeable bar option so you will be able to use more gpu memory. The list input that doggy suggests is a good way to reduce the inputs and gpu memory.
swamiforlife2
#4 Posted : Friday, December 8, 2023 10:54:29 PM(UTC)
swamiforlife2
I am using a RTX 2060 gpu.
nikosman88
#5 Posted : Friday, December 8, 2023 11:59:12 PM(UTC)
nikosman88
Greece
So no resizeable bar. If you not allready do it,enable from vmix settings-->perfomance the high input perfomance mode.Also if you enable the show gpu/cpu alerts and making tests you will find from what point and up gives you the gpu overload message that causes vmix to lag
Guest (5)
