Lzrd
#1 Posted : Wednesday, December 17, 2014 7:52:53 PM(UTC)
Lzrd
- Simple features which I miss a lot is: that shortcut OverlayInputAllOff could have effect option. Now it just cuts out all graphics and you can't make them disappear by fading.
To add OverlayInputAllOn shortcut option which could bring back all graphics which you turned off before would be very convenient as well. Because if you use scoreboard (1st overlay) with cut off clock from other camera (2nd overlay) and add logo (3rd) it is diffcult to manage 3 or 4 layers when you want to play comercials or smth like that.
- When adding Text field in scoreboard for sport team points, title designer could have special option for adding buttons liek +1; +2; +3; -1; -2; -3; for much more easyer points counting.
- I miss possibilitie to use image seaquences for graphics show up. It would be great if it would be possible to add not only picture but image sequence in .xmal. This could improve production value when graphics could show up animated (as it does title software I used before).
- Adding camer input with cropping/keying feature in same .xmal as scoreboard for placing clock next to it would be great feature as well. In this case we could save one from 4 overlays.
- More hi-end feature would be to add some kind of script to read digits from camera source which is capturing scoreboard of match and send information as digital numbers (pints, fouls, time) to scorebord for broadcasting in vmix what could be fantastic and very nice looking feature without cropped clock from camera and automatic point calculator.
#2 Posted : Thursday, December 18, 2014 12:56:18 AM(UTC)
Unless I misunderstand the option request some workarounds currently available.
- create shortcutkey to set overlay of which in turns triggers another shortcut for the other overlay
- put all titles in a multiview and set unset with shortcut
- any textfield accepts +1 +2 etc for counting through shortcut ( or api): settext +=1, -=1 etc
reading scoreboards etc : scoreocr for example
smileys
#3 Posted: : Sunday, May 24, 2015 6:39:49 PM(UTC)
smileys
Just a follow up to see if this "- When adding Text field in scoreboard for sport team points, title designer could have special option for adding buttons liek +1; +2; +3; -1; -2; -3; for much more easyer points counting." option was adopted.
That would certainly be appreciated especially while using the 'Web Site Address' on a table/phone to update the scores
#4 Posted : Monday, May 25, 2015 4:39:46 AM(UTC)
Title designer :
- Add Text field (name it)
- give it a numeric value (ex 0)
- save title
vMix:
- Load created title
- Settings -> Shortcuts ( to add/create one)
- Key = choose a key
- Function = Set Text
- Input = your loaded title
- Title = your created text field
- Value = +=1 (if you want to count up by 1)
- Title = give it a name ( ex 'Add One' )
- Ok = save the shortcut
- open shortcutwindow or web interface (locally, tablet or phone)
- click on the button you named 'Add one' (or press your shortcut key)
- see the value change up by 1
smileys on 7/15/2015(UTC)
smileys
#5 Posted : Wednesday, July 15, 2015 4:52:49 AM(UTC)
smileys
thanks doggy, it does work a treat
is there also a option to setimage, were there is a default images and upon pressing the shortcut, it changes that image
