I have an issue in vmix, latest version. This behaviour I can only observe in vMix.
All windows I open inside of vMix, Input Settings, Program settings and so on, behave strangely. They all drag weird when I move my mouse. Like they are on ice or if I'd be draggin them through a thick goo. I know it sounds strange. I click and hold on the upper window bar, to move the window and when I do, the window moves with a certain delay. Sometimes the window arrives later than the movement of my physical mouse. The mouse cursor also inherits this behaviour, but only when i drag a window. Not when using the mouse normally inside of vMix.
Could this be related to a Windows (10) scaling setting, or a NVidia VSYNC setting?
Joined: 7/1/2023(UTC) Posts: 16  Location: Bridgetown Thanks: 2 times
Check the mouse properties to see if you have the "Turn on Clock-Lock" ticked, and untick it....had something similar to that crap happen to me a few times......
