#1 Posted : Sunday, December 14, 2014 9:19:42 PM(UTC)
Was thanked: 4726 time(s) in 1618 post(s)
This thread will be used for all minor updates for vMix 14.
To install these updates, visit the download page, or click the "Update Available" link in vMix.
http://www.vmixhd.com/download.aspx
vMix 14 14.0.0.105 (includes changes in .102)
* New Graphics Adapter selection box in vMix Settings -> Performance
This can help on multi graphics card systems in cases where the built in graphics is being selected over the dedicated graphics
Note that multi graphics card systems are not recommended, but this can improve performance if you have to use them.
* Fixed Video Delay issues when resetting associated camera
will now automatically reset as required
* Improved UV virtual set performance
* Fixed bug where External Button could not be stopped if no outputs
were enabled
* Recording will reconfigure automatically with new settings when opening a different preset
* Fixed collapsed state bug when resetting an input
* Presets now remember last saved / opened folder
pasingshot on 12/25/2014(UTC), madness on 1/16/2015(UTC)
#2 Posted : Sunday, December 21, 2014 6:36:00 AM(UTC)
vMix 14 14.0.0.106
* Fixed bug when changing Title selection on an existing shortcut using the SetText function.
#3 Posted : Friday, January 16, 2015 12:31:34 AM(UTC)
14.0.0.112
* User interface improvements including new T-Bar and the ability to drag the Inputs bar to add new rows.
* REC/EXT/STREAM and SOLO buttons moved to next to the Fullscreen button
* Improved performance when running a second display on some systems
* Better handling when second display is unplugged
* FFMPEG Streaming will now auto reconnect up to 3 times when connection is lost.
* FFMPEG streaming will show the streaming button as orange during bad network conditions or loss of connectivity.
* New Threads and Network Buffer options for FFMPEG streaming
madness on 1/16/2015(UTC), Ittaidv on 1/16/2015(UTC)
