Images Assigned to Shortcuts
We have three people running vmix and are looking to standardize our templates.
We run off the web controller as we have hundreds of assets we may need to call up.
Is there any way to relink the images assigned to Shortcuts, aside from manually going through them all? Or for them to be saved into the template?
The inputs all show in the preset when copied over to a new computer, and the shortcuts exist, but for some reason the links are broken even though the file architecture is the same.
Thanks!
Joined: 4/23/2017(UTC) Posts: 1,493  Location: Germany Thanks: 3 times Was thanked: 198 time(s) in 178 post(s)
You can use the "save as bundle" option. This will pack all the assets into a single file which you can open on other computers. I don't like the temp structure of that process so I use onedrive/sharepoint for my assets. As far as the link is consistent and accessible the asset is showing up as expected.
