LucaL
#1 Posted : Monday, November 6, 2023 2:26:51 AM(UTC)
LucaL
Canada
I just returned a 1000$ Fomako 30x for the image quality that was no acceptable for our live productions.
I'm trying to match the image (to a certain point) to a 2014 Pwx-X70 and it wasn't doing it.
The colors got close, even somewhat acceptable after some tweaking in the web interface.
But the general quality, the sharpness/focus etc., wasn't there.
It was pretty hard to get the right focus at 30x and that is the range and focal length a need this type of camera for.
Otherwise I wish I could have kept it. Web interface was decent ,the NDI,POE all worked out of the box.
I really need a suggestion to find a better PTZ camera with the same specs.
I will obviously double the budget, bit I cannot go above 2k-2.5k
.. and 4k would be nice , but 1080p60 is enough for what we do..
Any suggestion will be greatly appreciated !
Thx
ovonder
#2 Posted : Tuesday, November 7, 2023 10:33:14 PM(UTC)
ovonder
You could have a look at the "Everet EVX230 NDI |HX3 PTZ Camera 30x zoom"
"The PTZ camera features resolutions up to 1080p60, a Sony 1/1.8″ 12MP CMOS sensor, and an integrated 30x optical zoom lens to capture high quality imagery. The camera offers also multiple simultaneous video output options including HDMI, 3G-SDI, UVC USB and IP streaming."
I have played with it, has POE+, NDI, Visca IP (you can select between HX2 or HX3 via the web-interface), simultaneously SDI and HDMI output.
Listed on supported vmix PTZ camera's https://www.vmix.com/sof...rdware.aspx#ptz-cameras.
thanks 1 user thanked ovonder for this useful post.
LucaL on 11/8/2023(UTC)
LucaL
#3 Posted : Wednesday, November 8, 2023 11:24:02 AM(UTC)
LucaL
Canada
Indeed this is pretty much what I was looking for. Thanks for the info.
I wonder how good is that 1/1.8 sensor. I like the fact that it is a little bigger than the 20x cams.
