Joined: 4/2/2022(UTC) Posts: 4  Location: Brazil Thanks: 1 times
I would suggest recording logs of the channels used during recording or live. For example, I don't like recording with a multicoder because the compression has to be high to record 4 cameras. I would like there to be a log or xml file of the channels used. This way, in post-production, you could use the original camera files. And exchange it for the low resolution file from the multicoder. Maybe it would even be integrated with the premiere's multicam
