Joined: 5/19/2020(UTC) Posts: 4  Location: Amador - Portugal
hi
I will try to explain the error
I have vmix receiving 2 ptz and one of them with audio from line
streaming to a rtmp wonza server
the live starts ok, and after one hour, more or less , the audi starts with small cuts (video ok) and then a lot of times in next 30 minutes until the end of live.
can you give more any help?
regards
Joined: 4/23/2017(UTC) Posts: 1,475  Location: Germany Thanks: 3 times Was thanked: 193 time(s) in 173 post(s)
Is the issue just between vmix and wowza or on the cam ingest?
vmix - wowza -> check your internet, ISP, Wowza instance
ingest -> check cam, network, increase buffer....
