Kayo33
#1 Posted : Thursday, October 26, 2023 2:48:36 AM(UTC)
Kayo33
Was thanked: 18 time(s) in 14 post(s)
hi everyone,
i'm looking to set up a pc replay for 8 x 1080p50 cams, at low cost
no broadcasts, no overlays, just monitoring replay for referee
there will be 32gb DDR4 ram and 2 x ssd m.2 4 x 4.0 (1 for windows and 1 for record)
but how to determine which other cpu / gpu components will suffice?
i find vmix recommendations quite high
https://i.postimg.cc/L6fVQYY5/vmix.jpg
if any of you are already using a dedicated 8 cams HD replay system or other, what is your config and what percentage is used by cpu and gpu in vmix?
thanks
