jet
#1 Posted : Friday, October 20, 2023 5:25:47 PM(UTC)
jet
Was thanked: 29 time(s) in 27 post(s)
No feedback from the program is given if the transition Duration is set over 9999 Milliseconds.
Now vMix 27.0.0.46 Beta (and older versions) it just ignores the user input over 9999 and set it silently to 1000 ms?...
Please give the user information about the maximum value allowed and increase the maximum allowed duration example to 30 000 ms. It's essential for many use cases. Better yet, set the limit to the highest possible value allowed by the variable type.
PeterH
#2 Posted : Saturday, October 21, 2023 10:55:56 PM(UTC)
PeterH
+1
thanks 1 user thanked PeterH for this useful post.
jet on 12/10/2023(UTC)
papaswan
#3 Posted : Tuesday, November 7, 2023 6:35:21 PM(UTC)
papaswan
Workaround
Change the parameter to frames and then you can specify a longer time period as the 9999 limit is in the input cell not to total time
thanks 1 user thanked papaswan for this useful post.
jet
#4 Posted : Thursday, November 9, 2023 5:14:00 AM(UTC)
jet
Originally Posted by: papaswan Go to Quoted Post
Workaround
Well, maybe works with scripts, but not with the GUI.
jet
#5 Posted : Saturday, January 6, 2024 5:36:09 AM(UTC)
jet
Now the bug part of this feature is finally fixed (vMix 27.0.0.58 beta).
Still waiting support for transitions longer than 9999ms..
