Livestream via Facebook Event fails, via Live Producer "Go Live" succeeds
Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
We've been using Facebook Live Video Events for more than two years to stream successfully (most of the time). We've found that it's more reliable with "Go live automatically at scheduled start time" OFF. But, for the past six weeks, the prescheduled Event livestream fails, but then facebook.com/live/producer Go Live works fine. (i.e. w/the proper streamkey set, pushing Stream stays yellow and then generates an error.) Any insights? The logs don't provide much insight. For 10/1: [rtmps @ 0532db60] Detected librtmp style URL parameters, these aren't supported by the libavformat internal RTMP handler currently enabled. See the documentation for the correct way to pass parameters. For 10/8: [dshow @ 00167d00] real-time buffer [vMix Video YV12] [video input] too full or near too full (72% of size: 128000000 [rtbufsize parameter])! frame dropped! It can't be a bandwidth issue, since the "Go Live" works immediately.
