jcraig
#1 Posted : Thursday, October 5, 2023 5:04:29 AM(UTC)
jcraig
When I crop or zoom an input to reframe a virtual guest coming in via NDI, it also affects and reshapes the same input being used as a layer in other shots (double box/4 box, etc), which I don't always need to do. What is the best way to edit the original source input without it affecting it in other layers?
Also, is there an easy way to re-align layered inputs in double, triple, and quad boxes? Without snapping, it's difficult to see if my layers are even.
Roy Sinclair
#2 Posted : Thursday, October 5, 2023 6:41:47 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
You crop or zoom it in the multi-view layer where you want it cropped or zoomed instead of at the input.
