Where do audio settings live if I want to recover them?
Joined: 1/25/2017(UTC) Posts: 39 Location: Los Angeles
Thanks: 9 times Was thanked: 2 time(s) in 2 post(s)
Recently had a problem recording to one of my drives, which caused vMix to have a HARD crash that basically reset its' preferences. Not sure how that happened.
I've been reconstituting my setup, loading a last saved state and my keyboard mapping. However, it appears at least part of my audio routing within vMix disappeared. I'm doing some things with 4 channel audio.
Is there a place where the previous audio setup might be saved? If not, is there a way to make sure I save it so that if this happens again, I don't have to work out what I did from scratch or hard to remember notes?
This has to do with
- Assigning an audio clip to a different buss (let's say B) - Routing that buss out to a certain monitor output - Setting that buss to channels 3&4 - Making sure that the busses remain separate (i.e. buss A and main don't rout to 3&$) - Making sure that a feedback loop isn't created anywhere
Rank:: Advanced Member
Joined: 11/19/2015(UTC) Posts: 30  Location: Netherlands Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
I have had that a couple of times after sudden power loss, those are general settings and not project settings. These settings are stored at %localappdata%\StudioCoast_Pty_Ltd\VMIX64.EXE_Url_5l40qvre1y15spmggwt1gelpnmwemdfj\23.0.0.65\user.config" Where the 23.0.0.65 points to the folder of the version. So each time you upgrade a version, a new folder is added. In same cases the user.config can get corrupted hence missing settings. I run a daily scheduled task like:
mkdir c:\backupsettingsvmix xcopy c:\programdata\vmix\settingbackups c:\backupsettingsvmix\settingsbackups /d copy "%localappdata%\iStream Studio\*.xml" c:\backupsettingsvmix copy "%localappdata%\iStream Studio\*.vmix" c:\backupsettingsvmix copy "%localappdata%\StudioCoast_Pty_Ltd\VMIX64.EXE_Url_5l40qvre1y15spmggwt1gelpnmwemdfj\25.0.0.29\user.config" c:\backupsettingsvmix
to make sure i can always restore the general settings in case needed.
 1 user thanked ovonder for this useful post.
