sojorner
#1 Posted : Monday, September 18, 2023 7:54:09 AM(UTC)
sojorner
I can't find anything on this, so I am assuming that it isn't possible right now.
I have a number of images I use frequently where I add another layer onto it. Since the layer region is the same each time, I've created / added a preset for the image. This works nice in that when I use the image and have an input to add as a layer, I simply click on the added preset and everything fits nicely.
However, I am finding myself using a number of different images that have a different layer region and have setup new presets accordingly. But, the added presets are not identified in anyway in the preset window. IS there a way to identify these so I know which preset goes with which image?
thanks
DJH
