Roy Sinclair
#1 Posted : Thursday, September 7, 2023 7:36:55 AM(UTC)
Roy Sinclair
Was thanked: 31 time(s) in 27 post(s)
Aren't you repeating https://forums.vmix.com/...-easier-control-of-DVD-s
If clarifying then it should be another post on that same thread.
thanks 1 user thanked Roy Sinclair for this useful post.
RichShumaker on 9/10/2023(UTC)
RichShumaker
#2 Posted : Sunday, September 10, 2023 3:56:16 PM(UTC)
RichShumaker
Was thanked: 28 time(s) in 23 post(s)
You are correct.
I had forgotten I posted that as I ran into it again when using DVD's again.
Thank you I will be deleting this in a few minutes.
Hopefully you see this before that.
RichShumaker
#3 Posted : Sunday, September 10, 2023 3:59:25 PM(UTC)
RichShumaker
okay so I have to figure out if I can delete the post.
I just deleted my original post and now it goes right to the first comment.
If an Admin reads this I was trying to remove this as it is a duplicate.
Thanks for your help on this.
