Feature Requests
Add direct inputs in list sending audio and video to vMixCall.
Joined: 8/26/2020(UTC) Posts: 17  Location: Velsen / The Netherlands Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Hi vMix,
Please add direct inputs in list sending audio and video to vMixCall. And the posibility to change the input you send to vMixCall with API command. For instance: you start a vmixcall, as operator you welcome the guest outside of the broadcast by send audio from input 12, and then change the send to audio input 11 (MixMinus)
Now we can only send video output 1-4 and Audiobus A-G to for instance vMixCall.
When you work with a X32(M32) you can input a mix(minus)bus from that mixer and send that direct to the caller. Now you lose a whole audio bus for that. If you can send direct inputs and/or Mix inputs to SRT/vMixcaller/NDI we get far more flexible with using vMix.
Feature Requests
