Our church has been using our ptz 30 SDI camera for about 2 years now and have been bringing it into Vmix through rtsp option. We recently upgraded our system to SDI and got an MD-HX decimator to scale the camera with but I'm unable to find a resolution and frame rate that works. Does anyone have a rate/resolution that I can scale to that Vmix sd supports?
If you're using vMix SD, then have you tried sending a SD resolution from the Decimator? e.g. 525i59.94
Of course the other question would be, what capture device are you using? In some cases the capture card can provide the scaling function.
