GT
How to create progress line script.
Joined: 9/27/2019(UTC) Posts: 49  Location: Kuressaare
Hi.
How about a process bar that keeps track of a given amount of time. Let's say the whole time is 70 seconds. Then the process bar is on the scale 0-100% and according to the given time the process bar moves. If the time has passed, the bar turns red, otherwise it is green and the background is white on the bar.
Is there a demo or does someone know how to do something like this? or give advice :)
Thank you :)
Joined: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
Might be quicker and simpler doing it in html/JavaScript and load in as a browser input A quick google gives the following as an example https://jsfiddle.net/63zdj6xh/
Joined: 10/31/2020(UTC) Posts: 205  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
An easy way is to just create a video in After Effect (or similar), and just play back the video in vMix. You can even pause/resume if necessary.
Joined: 6/16/2020(UTC) Posts: 77  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
Excuse me, I know it's the gt sub forum but have you tried it in xaml, there are the necessary tools to do it. greetings translated from Spanish to English by Google
 u.xaml (2kb) downloaded 15 time(s).Here are some tests, modify them to your liking, but it is an idea of what it is more or less like, greetings. translated from Spanish to English by Google
GT
