error on DIY animated lower third
Hi all, i'm testing vmix for the first time, and i would like to create my own graphics... I'm noob on visual studio, but i have create a lower third for the first test... the animation is ok, text ok, gut at last it move up and text disappear... can you give me a hint for the error? lower third is in attachment... File Attachment(s):  lower.xaml (7kb) downloaded 23 time(s).You cannot view/download attachments. Try to login or register.
Joined: 4/18/2014(UTC) Posts: 55 Location: Birmingham, United Kingdom
Was thanked: 9 time(s) in 6 post(s)
You need to make sure all elements within the default scene are placed correctly. When storyboard1 has finished playing, it will show the static default scene. So you need to make sure that both storyboard1, storyboard2 and the default scene are all positioned correctly.
 1 user thanked gazreyn for this useful post.
gazreyn wrote:You need to make sure all elements within the default scene are placed correctly. When storyboard1 has finished playing, it will show the static default scene. So you need to make sure that both storyboard1, storyboard2 and the default scene are all positioned correctly. Thanks for the reply! It was the problem! I checked my project and now it works... thank you very much!
