VMIX SHORTCUT TO PLAY NEXT INPUT
Is there a shortcut I can use on my Stream Deck so that I can press one key to play the next input instead of having to program a stream deck button to play each input?
Originally Posted by: Ken Robinson  Is there a shortcut I can use on my Stream Deck so that I can press one key to play the next input instead of having to program a stream deck button to play each input? Hello. The next input in vmix inputs or the next item in a vmix list input?
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Ken Robinson  Is there a shortcut I can use on my Stream Deck so that I can press one key to play the next input instead of having to program a stream deck button to play each input? Seems to be a weird question. First this would imply you only have playable inputs to begin with (like videos) Any shortcut Avaialble in vMix can be driven by a streamdeck or any other controler Better look into usng playlists or List for such use
