Imported Lower Thirds from AE Issue
Joined: 7/8/2023(UTC) Posts: 21  Location: Great State of Tennessee Thanks: 12 times
I have created animated lower thirds in AE (I wanted something more complex the the built-in editor).
How do I turn it on and off and have the video animation restart each time?
1) I have it imported as a Video Input 2) I have that Input selected as a layer in my output block 3) It animates the first time, but if I disable it and then turn it back on later... The animation does not restart. 4) I have automatically restart after transition checkbox on.
Please advise on how to have it animate each time. Is there a best practice for bring AE graphics into VMix?
You have been a member since:: 2/8/2023(UTC) Posts: 24  Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
Export from AE to PNG sequenc. The PNG sequence is import to GT designer Using GT to add text
 1 user thanked kuuminsh for this useful post.
