MoSchoen
#1 Posted : Sunday, July 16, 2023 10:46:03 PM(UTC)
MoSchoen
Hello all!
I've been using vmix since vmix 23 and I have a stream deck. I made a key that toggles on and off my reverb plug in and it works in the background. However on the Audio settings menu the check box doesn't check and uncheck making it very hard to understand if the plug in is on or off.
Hoping for a fix on this.
All the best! Mo.
