Feature Requests
Add information to XML API for SRT and NDI input connection states
Joined: 3/7/2022(UTC) Posts: 72  Location: Munich Was thanked: 33 time(s) in 17 post(s)
We are using SRT and NDI input. Unfortunately, the XML API has no real connection state information for those inputs. This way one cannot react on situations where incoming SRT or NDI streams fail. For both it would be best if it isn't just the connections, but information whether really any FRAMES(!) are received. This would allow vMix scripts to react on those situations and, for instance, switch inputs in a heartbeat-failure situation on playout systems, etc.
Joined: 12/24/2021(UTC) Posts: 733  Location: athens Thanks: 166 times Was thanked: 99 time(s) in 95 post(s)
Joined: 6/5/2020(UTC) Posts: 91  Location: Jakarta Thanks: 17 times Was thanked: 5 time(s) in 3 post(s)
Joined: 8/26/2020(UTC) Posts: 17  Location: Velsen / The Netherlands Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Feature Requests
