Geffers
#1 Posted : Sunday, June 18, 2023 6:25:00 PM(UTC)
Geffers
On several machines we're seeing high memory on VMixNDI Helper - 170Megs and 12% cpu. An evident memory leak, but oddly not across the board.
VMIX currently has no NDI enabled (we've previously used it). Obviously restarting clears this down, but after a day or so, it's back high.
Solution is to rename the .exe to .memoryhog, but... not really a good solution. This machine is running VMIX v25 (and we'd have to pay for an upgrade).
Why does it even run, when no NDI is being used?
