JasperHendrickx
#1 Posted : Friday, June 9, 2023 6:28:20 PM(UTC)
JasperHendrickx
I'm very new to scripting for vMix (and scripting in general).
I'm looking for a script that writes the current recordingtime to a text document (or logfile) whenever a certain text value changes. And it would be even better if it also writes the new text value next to the recordingtime.
I allready tried this:
Function=WriteDurationToRecordingLog&Input=brugge-agendapunten.gtzip&Value=&SelectedName=TextBlock1.Text&Index=0
But i don't know what the Value should be...
Many thanks in regards.
nikosman88
#2 Posted : Saturday, June 10, 2023 6:34:33 AM(UTC)
nikosman88
Greece
Hello based in this script https://forums.vmix.com/...or-commercials#post99914 i modified it to make something that may fit what you need
Code:
' Script von Mats Julian Steffens
' www.lvstrm.de
Dim dateinamealt As String = ""
Dim startTime As DateTime = DateTime.Now
Dim previousText As String = ""
Dim currentText As String = ""
Do
    Dim datum As String
    datum = DateTime.Now.ToString("yyMMdd")
    Dim filename As String
    filename = "C:\vMix log\" + datum + "-vmixlog.txt"
    If (Not System.IO.File.Exists(filename)) Then
        My.Computer.FileSystem.WriteAllText(filename, " ", True)
    End If
    Dim timestamp As DateTime
    timestamp = DateTime.Now
    ' Ανακτήστε το XML από το VMix API
    Dim xml As String = API.XML()
    Dim x As New System.Xml.XmlDocument
    x.LoadXml(xml)
    Dim activinput As String = (x.SelectSingleNode("/vmix/active").InnerText)
    Dim inputname As String = (x.SelectSingleNode("//input[@number=" + activinput + "]/@shortTitle").Value)
    Dim dateiname As String = (x.SelectSingleNode("//input[@number=" + activinput + "]/@title").Value)
    Dim currentTextElement As System.Xml.XmlNode = x.SelectSingleNode("//text[@index='0' and @name='rectext.Text']")
    Dim inputnamelaenge As Integer
    If (inputname = dateiname) Then
        inputnamelaenge = 0
    Else
        inputnamelaenge = inputname.Length() + 3
    End If
    Dim inputString As String
    ' Γράψτε το αρχείο
    If (dateinamealt <> dateiname) Then
        Dim elapsedTime As TimeSpan = timestamp - startTime
        Dim duration As String = String.Format("{0:mm':'ss}", elapsedTime)
        inputString = timestamp.ToString("dd/MM/yy HH:mm:ss") + " " + duration + " " + dateiname.Substring(inputnamelaenge) + " " + currentText + Environment.NewLine
        Console.WriteLine(inputString)
        My.Computer.FileSystem.WriteAllText(filename, inputString, True)
        dateinamealt = dateiname
    End If
    ' Έλεγχος αν το κείμενο έχει αλλάξει
    If currentTextElement IsNot Nothing Then
        currentText = currentTextElement.InnerText
    Else
        currentText = ""
    End If
    If currentText <> previousText Then
        previousText = currentText
    End If
    Sleep(1000)
Loop
Make a folder in C:\Vmix log. Start this script same time you start record and in the folder will be created a txt file that will be like this
09/06/23 22:59:50 00:00:00.0019946 NDI DESKTOP-OJV2PL8 (vMix - Output 1) Hello
09/06/23 23:00:09 00:00:19.0321253 NDI DESKTOP-OJV2PL8 (vMix - Output 1) ΒΥΕ
09/06/23 23:00:10 00:00:20.0332841 NDI DESKTOP-OJV2PL8 (vMix - Output 1) GOOD
09/06/23 23:00:21 00:00:31.0460639 NDI DESKTOP-OJV2PL8 (vMix - Output 1) NIGHT
09/06/23 23:00:22 00:00:32.0473666 NDI DESKTOP-OJV2PL8 (vMix - Output 1) NIGHT
09/06/23 23:00:23 00:00:33.0489171 NDI DESKTOP-OJV2PL8 (vMix - Output 1) NIGHT
09/06/23 23:00:32 00:00:42.0583673 NDI DESKTOP-OJV2PL8 (vMix - Output 1) VMIX
09/06/23 23:00:33 00:00:43.0599807 NDI DESKTOP-OJV2PL8 (vMix - Output 1) MORNING
Ιn which lines we have the date-time,the active source and from when we start script/record and starting from 0 in which point of record the text changed
Also to be able the script know when the text changes i picked up a random title from vmix templates, open it to gt designer and i changed the layer name from Headline.text to rectext.text. So in vmix api xml is created when we use the title we modified an entry that is like <text index="0" name="rectext.Text">MORNING</text> in order the script must know where to look for. This line can be changed in whatever you want by changing this line in code script
Code:
make a title with the name layer you want and change it to script also and modify it by your needs.
I hope that this, helps you
thanks 1 user thanked nikosman88 for this useful post.
JasperHendrickx on 2/10/2024(UTC)
#3 Posted : Saturday, June 10, 2023 11:40:13 AM(UTC)
Why are you using the datetime when the question was for the current recording time that can be retrieved strait from the API XML ?
The text in the title can more easely be retrieved with the input.find() function
