Joined: 12/6/2020(UTC) Posts: 10  Location: North Carolina
I have several Virtual PTZ presets in my vmix setup. There are times when I put a preset in preview and needs to be adjusted to fit the group that the camera is on. Once I adjust the camera, I go to move the Virtual PTZ into Input. When I do this, the Virtual PTZ goes back to the Virtual PTZ Preset and I lose the adjustments that I did. Why does vmix lose the adjustments and is there a way to fix this. I know that I can go to the actual camera and an "Update PTZ/Virtual Input" but that takes too long.
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: kclark  I have several Virtual PTZ presets in my vmix setup. There are times when I put a preset in preview and needs to be adjusted to fit the group that the camera is on. Once I adjust the camera, I go to move the Virtual PTZ into Input. When I do this, the Virtual PTZ goes back to the Virtual PTZ Preset and I lose the adjustments that I did. Why does vmix lose the adjustments and is there a way to fix this. I know that I can go to the actual camera and an "Update PTZ/Virtual Input" but that takes too long. Check the shortcut list , believe there is one to update a virtual ptz
Originally Posted by: doggy  Check the shortcut list , believe there is one to update a virtual ptz I get that but I know there is either a setting or some way to fix this. I have another vmix setup where the virtual ptz cameras don't move at all when adjusted. There are 2 differences between these setups. The setup where the cameras don't move is Version 25 and I have a button for each camera that puts each camera in preview when pressed (using skeys). I have the ptz positions setup to only move the camera (I believe) and not move the camera and put into preview. The setup where the cameras do move is Version 26 and each ptz is a separate button on xkeys and the button also puts the ptz into preview at the same time.
