formatta2003
#1 Posted : Wednesday, May 24, 2023 11:20:59 PM(UTC)
formatta2003
To free space on the hard disk and to do some cleaning, I eliminated the Windows temp folder ... but I saw that some projects have lost many files, when reopening the project they are not recreated by creating many problems
It is not correct that VMIX saves the files used in the temp folder. Is it possible to solve this problem ??? !!!!
thank you
MC
