Feature Requests
Set GT Rotate animation value
Rank:: Newbie
Joined: 1/9/2023(UTC) Posts: 7  Was thanked: 1 time(s) in 1 post(s)
For data change in/out animations I'd like for an item to only rotate 180 degrees a certain way, however it seems like it's only possible to rotate a full 360 degrees at the moment. Would it be possible to add in a rotation value so you can have something rotate as much or as little as you'd like?
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Scar7752  For data change in/out animations I'd like for an item to only rotate 180 degrees a certain way, however it seems like it's only possible to rotate a full 360 degrees at the moment. Would it be possible to add in a rotation value so you can have something rotate as much or as little as you'd like? try combining multiple animation into one , play with timing
Rank:: Newbie
Originally Posted by: doggy  Originally Posted by: Scar7752  For data change in/out animations I'd like for an item to only rotate 180 degrees a certain way, however it seems like it's only possible to rotate a full 360 degrees at the moment. Would it be possible to add in a rotation value so you can have something rotate as much or as little as you'd like? try combining multiple animation into one , play with timing Is this possible to do with data changes though? I'm trying to be a seamless 360 between data change in and data change out, so 180 for each, but GT made me wait for all change in animations to complete before it started change out animations.
Feature Requests
