RichShumaker
#1 Posted : Wednesday, May 10, 2023 1:37:05 PM(UTC)
RichShumaker
Was thanked: 28 time(s) in 23 post(s)
I love the new LUT's feature except it is kind of useless as you can not turn them on and off.
It would be cool to stack all the looks for a production into a single Effects Tab and then turn them off as needed.
So the Effects tab would look like this
X - LUT 1
0 - LUT 2
X - LUT 3
X - LUT 4
X - LUT 5
X - LUT 6
I am on LUT 2 right now.
My Production Example
For my Production I wanted to have a Black and White Section of the show.
When I transition I would turn on the B & W LUT and now all of the on screen things become B & W.
Yes I could easily create a new Input with all of the things and then LUT that Innput BUT what if I want different looks for every element on screen. This workaround only works if they all get the same LUT.
Oh well then create new Inputs for each look you want to use and use a different LUT on each. Also works BUT very time consuming and complicated instead of just turning on and off something with a simple command.
