is there an api that allows you to send a command to vmix to be able to change the folder from where you take the photos?
Joined: 12/27/2012(UTC) Posts: 5,509  Location: Belgium Thanks: 316 times Was thanked: 1020 time(s) in 838 post(s)
Originally Posted by: mixsystem  is there an api that allows you to send a command to vmix to be able to change the folder from where you take the photos? to add yes, change no
